Logitech Harmony Smart Keyboard On/Off Switch Replacement
  1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: step 1, image 1 of 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: step 1, image 2 of 2
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 2, image 1 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 2, image 2 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 2, image 3 of 3
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 3, image 1 of 1
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 4, image 1 of 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 4, image 2 of 2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 5, image 1 of 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 5, image 2 of 2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 6, image 1 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 6, image 2 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 6, image 3 of 3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 7, image 1 of 2 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 7, image 2 of 2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 8, image 1 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 8, image 2 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 8, image 3 of 3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 9, image 1 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 9, image 2 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 9, image 3 of 3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: step 10, image 1 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: step 10, image 2 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: step 10, image 3 of 3
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  11. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 11, image 1 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 11, image 2 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 11, image 3 of 3
    • Set aside the front panel and locate the green card atop the on/off switch on the back panel.
    • Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
  12. Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 12, image 1 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 12, image 2 of 3 Logitech Harmony Smart Keyboard On/Off Switch Replacement: step 12, image 3 of 3
    • Lift up and hold the left side of the green card with one index finger.
    • Grip and pull the on/off switch out with your other index finger and thumb.
2 other people completed this guide.
Hayley Nichols
525 Reputation
4 Guides authored
CSU Fullerton, Team S1-G2, Bruce Fall 2017 Member of CSU Fullerton, Team S1-G2, Bruce Fall 2017
CSUF-BRUCE-F17S1G2
3 Members
10 Guides authored
1 Guide Comment
please share switch rear side.. and where could we buy this switch.. ?
Praveen Krishnan - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 4,913
