Logitech Harmony Touch Motherboard Replacement
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: step 1, image 1 of 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: step 1, image 2 of 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Open the latch that covers the charging port.
    • Remove the black sticker, then remove the screw with the indicated screwdriver.
    • Take the plastic opening tool, and run it down the side of the remote to pop the case open.
    • While doing this step, there are three wires that connect the two pieces. Be sure not to rip the wires out.
    • Detach the white clamp in order to partially disconnect the case from the motherboard.
  2. Logitech Harmony Touch Motherboard Replacement: step 2, image 1 of 3 Logitech Harmony Touch Motherboard Replacement: step 2, image 2 of 3 Logitech Harmony Touch Motherboard Replacement: step 2, image 3 of 3
    • Peel back the thin yellow plastic film and detach the clip found underneath.
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver.
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all of the buttons and remove them from the case.
Lennox Saliva-Rojas
290 Reputation
2 Guides authored
USF Tampa, Team S4-G2, Eyestone Fall 2017 Member of USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 930
