Logitech Harmony Touch Screen Replacement
  1. Logitech Harmony Touch Screen Replacement, Screen: step 1, image 1 of 3 Logitech Harmony Touch Screen Replacement, Screen: step 1, image 2 of 3 Logitech Harmony Touch Screen Replacement, Screen: step 1, image 3 of 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screw driver.
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to partially disconnect the case from the motherboard.
  2. Logitech Harmony Touch Screen Replacement: step 2, image 1 of 2 Logitech Harmony Touch Screen Replacement: step 2, image 2 of 2
    • Peel back thin yellow plastic film and detach the clip found underneath.
    • Use a Phillips #00 to remove the screws that connect the motherboard to the case.
  3. Logitech Harmony Touch Screen Replacement: step 3, image 1 of 3 Logitech Harmony Touch Screen Replacement: step 3, image 2 of 3 Logitech Harmony Touch Screen Replacement: step 3, image 3 of 3
    • Carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should be able to access the screen which is located on the back of the motherboard.
  4. Logitech Harmony Touch Screen Replacement: step 4, image 1 of 1
    • Separate the screen from the motherboard.
2 other people completed this guide.
Nicholas Townsend
285 Reputation
2 Guides authored
USF Tampa, Team S4-G2, Eyestone Fall 2017 Member of USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Members
5 Guides authored
2 Guide Comments
Hallo
Mit dieser Anleitung klappt das wechseln bestimmt.Ich habe nur eine frage “Woher bekomme ich ein Touchscreen für die Fernbedienung”?
Ich habe die Ultimate und bei mir ist der Touchscreen defekt.Doch ich habe noch kein Ersatz gefunden. :-( Können sie mir da weiter helfen?
belfrea - Reply
do you have the lcd screen P/N???
Alejandro Ortiz - Reply
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 51
All Time: 5,123
