Logitech Harmony Ultimate Charging Station Motherboard Replacement
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: step 1, image 1 of 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: step 1, image 2 of 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: step 1, image 3 of 3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 2, image 1 of 2 Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 3, image 1 of 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 3, image 2 of 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 3, image 3 of 3
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 4, image 1 of 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 4, image 2 of 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: step 4, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
Lucas Reynolds
339 Reputation
2 Guides authored
USF Tampa, Team 8-1, Eyestone Fall 2015 Member of USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,908
