Logitech Harmony Ultimate Harmony Hub Motherboard Replacement
  1. Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Screws: step 1, image 1 of 3 Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Screws: step 1, image 2 of 3 Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Screws: step 1, image 3 of 3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove the four 6mm Phillips #0 screws from the bottom of the hub.
  2. Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Top Shell: step 2, image 1 of 2 Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Top Shell: step 2, image 2 of 2
    • Use a plastic opening tool to remove the top shell of the device.
  3. Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Motherboard: step 3, image 1 of 3 Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Motherboard: step 3, image 2 of 3 Logitech Harmony Ultimate Harmony Hub Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Remove the single 6 mm Phillips #0 screw from the motherboard.
    • Pull the black tabs back and lift the motherboard.
Lucas Reynolds
339 Reputation
2 Guides authored
USF Tampa, Team 8-1, Eyestone Fall 2015 Member of USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,547
