Logitech K345 Membrane Replacement
  1. Logitech K345 Membrane Replacement, Battery: step 1, image 1 of 2 Logitech K345 Membrane Replacement, Battery: step 1, image 2 of 2
    • Gently flip over your keyboard so that the keys are facing down.
  2. Logitech K345 Membrane Replacement: step 2, image 1 of 3 Logitech K345 Membrane Replacement: step 2, image 2 of 3 Logitech K345 Membrane Replacement: step 2, image 3 of 3
    • Slide open the battery compartment on the bottom of the keyboard.
  3. Logitech K345 Membrane Replacement: step 3, image 1 of 1
    • Remove batteries from the compartment.
  4. Logitech K345 Membrane Replacement, Membrane: step 4, image 1 of 1
    • Remove the thirteen 5.3 mm screws from the back of the keyboard using a Phillips #0 screwdriver.
  5. Logitech K345 Membrane Replacement: step 5, image 1 of 2 Logitech K345 Membrane Replacement: step 5, image 2 of 2
    • Pry up the corner rubber pads using a Jimmy.
  6. Logitech K345 Membrane Replacement: step 6, image 1 of 2 Logitech K345 Membrane Replacement: step 6, image 2 of 2
    • Remove the two 5.3 mm screws from the corners with a Phillips #0 screwdriver.
  7. Logitech K345 Membrane Replacement: step 7, image 1 of 2 Logitech K345 Membrane Replacement: step 7, image 2 of 2
    • Use your hands and opening picks to remove the back of the keyboard.
  8. Logitech K345 Membrane Replacement: step 8, image 1 of 3 Logitech K345 Membrane Replacement: step 8, image 2 of 3 Logitech K345 Membrane Replacement: step 8, image 3 of 3
    • Remove the keyboard membrane.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 40
All Time: 555
