Logitech K345 On/Off Button Replacement
  1. Logitech K345 On/Off Button Replacement, Membrane: step 1, image 1 of 1
    • Remove the thirteen 5.3 mm screws from the back of the keyboard using a Phillips #0 screwdriver.
  2. Logitech K345 On/Off Button Replacement: step 2, image 1 of 2 Logitech K345 On/Off Button Replacement: step 2, image 2 of 2
    • Pry up the corner rubber pads using a Jimmy.
  3. Logitech K345 On/Off Button Replacement: step 3, image 1 of 2 Logitech K345 On/Off Button Replacement: step 3, image 2 of 2
    • Remove the two 5.3 mm screws from the corners with a Phillips #0 screwdriver.
  4. Logitech K345 On/Off Button Replacement: step 4, image 1 of 2 Logitech K345 On/Off Button Replacement: step 4, image 2 of 2
    • Use your hands and opening picks to remove the back of the keyboard.
  5. Logitech K345 On/Off Button Replacement: step 5, image 1 of 3 Logitech K345 On/Off Button Replacement: step 5, image 2 of 3 Logitech K345 On/Off Button Replacement: step 5, image 3 of 3
    • Remove the keyboard membrane.
  6. Logitech K345 On/Off Button Replacement, On/Off Button: step 6, image 1 of 2 Logitech K345 On/Off Button Replacement, On/Off Button: step 6, image 2 of 2
    • Pry open the sides holding the On/Off button using an opening pick.
  7. Logitech K345 On/Off Button Replacement: step 7, image 1 of 1
    • Remove the on/off button.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 544
