Logitech K400r Wireless Keyboard Disassembly & Cleaning
  1. Logitech K400r Wireless Keyboard Disassembly & Cleaning, Keyboard: step 1, image 1 of 1
    • Use a small Phillips head screwdriver to unscrew all visible screws on the back of the keyboard.
    • Keep all screws in a safe place for easy reassembly.
    • Ensure the keyboard is shut off before disassembly.
  2. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 2, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 2, image 2 of 2
    • Remove the battery port so that the batteries are exposed and take them out.
    • Unscrew the screw that is located in the battery port.
  3. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 3, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 3, image 2 of 2
    • Remove the two rubber pieces off the top of the keyboard.
    • Unscrew screws located under the rubber pieces.
  4. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 4, image 1 of 1
    • Unscrew the screws located under the label in the center of the back of the keyboard.
  5. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 5, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 5, image 2 of 2
    • Once you have removed all screws from the exterior, the keyboard should be able to split open and come apart.
    • Carefully pry open the keyboard. You can use your screwdriver or any prying tool.
  6. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 6, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 6, image 2 of 2
    • Remove the key matrix, which is soft and should be clear or white.
    • Using a dry cloth, lightly wipe off the key matrix.
  7. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 7, image 1 of 1
    • Using a dry cotton swab, lightly dust off the mousepad and area around the keys on the outside of the board.
  8. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 8, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 8, image 2 of 2
    • Using compressed air, dust in between the key switches and inside the circuit grid.
    • After you have cleaned all components of your keyboard, place the key matrix, key switchboard, and circuit grid back inside the keyboard.
    • Place all screws back into the exterior of the keyboard and screw them in tightly.
    • Place batteries back in battery compartment and close the battery port.
    • Keyboard is reassembled!
Finish Line
3 other people completed this guide.
Dustie Flowers
229 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 55
All Time: 1,950
