Logitech M100 Switch Replacement
  1. Logitech M100 Switch Replacement, Switches: step 1, image 1 of 1
    • Disconnect the mouse from any devices before attempting to remove any parts or starting the repair.
    • Flip your mouse over so the bottom is facing up.
  2. Logitech M100 Switch Replacement: step 2, image 1 of 1
    • Use a small Phillips #00 screwdriver to remove the single screw at the bottom of the mouse.
  3. Logitech M100 Switch Replacement: step 3, image 1 of 2 Logitech M100 Switch Replacement: step 3, image 2 of 2
    • Turn your mouse over so it is facing right side up.
    • Use a spudger or your hands to carefully separate the top from the bottom housing.
    • It's important to remove the top housing while leaving the bottom in place, as the scroll wheel and other internal components may fall out otherwise.
  4. Logitech M100 Switch Replacement: step 4, image 1 of 1
    • Remove the external cable from the slot at the front of the mouse.
  5. Logitech M100 Switch Replacement: step 5, image 1 of 3 Logitech M100 Switch Replacement: step 5, image 2 of 3 Logitech M100 Switch Replacement: step 5, image 3 of 3
    • Remove the circuit board from the mouse by pushing down at the back and lifting up at the front.
  6. Logitech M100 Switch Replacement: step 6, image 1 of 2 Logitech M100 Switch Replacement: step 6, image 2 of 2
    • Lift the scroll wheel from the board.
    • There should be a total of four parts that make up the scroll wheel.
  7. Logitech M100 Switch Replacement: step 7, image 1 of 1
    • Pull the USB cable away from the connector in the same direction as the individual wires to remove it from the motherboard.
    • This step may prove difficult with just your hands. Use a spudger if you need to.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  8. Logitech M100 Switch Replacement: step 8, image 1 of 1
    • Find a suitable method to hold the circuit board in place so you don't have to hold it in your hands.
    • Use a small vice to keep it in place or helping hands for this next step.
  9. Logitech M100 Switch Replacement: step 9, image 1 of 3 Logitech M100 Switch Replacement: step 9, image 2 of 3 Logitech M100 Switch Replacement: step 9, image 3 of 3
    • Use a soldering iron to heat the solder points securing both switches, and remove the switches using tweezers.
    • The soldering iron and the solder holding the switch in place will be very hot and can burn you.
  10. Logitech M100 Switch Replacement: step 10, image 1 of 3 Logitech M100 Switch Replacement: step 10, image 2 of 3 Logitech M100 Switch Replacement: step 10, image 3 of 3
    • Replace each switch and solder it to the circuit board.
    • The soldering wire may conduct heat up to the hand holding it.
    • Be sure to work in a well ventilated space as the solder may emit smoke.
    • You can use tape to hold the switch in place while soldering.
  11. Logitech M100 Switch Replacement: step 11, image 1 of 2 Logitech M100 Switch Replacement: step 11, image 2 of 2
    • Reassemble the mouse by following steps 2-7 in reverse order.
Congratulations, you have now replaced the clickers on your mouse and can continue using it!
2 other people completed this guide.
Diego De La Fuente
211 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 756
