Logitech M100 USB Cable Replacement
  1. Logitech M100 USB Cable Replacement, USB Cable: step 1, image 1 of 2 Logitech M100 USB Cable Replacement, USB Cable: step 1, image 2 of 2
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
  2. Logitech M100 USB Cable Replacement: step 2, image 1 of 2 Logitech M100 USB Cable Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
  3. Logitech M100 USB Cable Replacement: step 3, image 1 of 2 Logitech M100 USB Cable Replacement: step 3, image 2 of 2
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
  4. Logitech M100 USB Cable Replacement: step 4, image 1 of 2 Logitech M100 USB Cable Replacement: step 4, image 2 of 2
    • Take the replacement USB cable and connect it to the mainboard.
  5. Logitech M100 USB Cable Replacement: step 5, image 1 of 2 Logitech M100 USB Cable Replacement: step 5, image 2 of 2
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
  6. Logitech M100 USB Cable Replacement: step 6, image 1 of 1
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
To reassemble, follow the steps in reverse order.
4 other people completed this guide.
Jake Janicke
161 Reputation
1 Guide authored
1 Guide Comment
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 42
All Time: 6,226
