Logitech M125 Button Plate Replacement
  1. Logitech M125 Button Plate Replacement, Button Plate: step 1, image 1 of 3 Logitech M125 Button Plate Replacement, Button Plate: step 1, image 2 of 3 Logitech M125 Button Plate Replacement, Button Plate: step 1, image 3 of 3
    • Turn the device over and remove the two 0.5mm screws near the front of the mouse by using a Phillips #0 screwdriver.
    • The black screws used in the Logitech M125 frame are all the same size and do not need special consideration for keeping them separated. Silver colored screws are used on the circuit board and have broader heads.
    • Once the screws are removed, open the mouse from the front as it pivots at the rear.
  2. Logitech M125 Button Plate Replacement: step 2, image 1 of 2 Logitech M125 Button Plate Replacement: step 2, image 2 of 2
    • Once the mouse is opened, remove the two black 0.5mm screws located towards the back of the mouse. These are the retention screws for the mouse button plate.
    • These screws will also require the Phillips #0 screwdriver.
  3. Logitech M125 Button Plate Replacement: step 3, image 1 of 3 Logitech M125 Button Plate Replacement: step 3, image 2 of 3 Logitech M125 Button Plate Replacement: step 3, image 3 of 3
    • There are two tabs that further secure the mouse buttons to the frame. They are located on either side of the mouse cord retracting mechanism.
    • The tighter confines of the mouse interior will be easier to navigate with metal prying tools. While plastic tools are preferred for most plastic devices, they are too large to access the left tab in the picture.
    • To dislodge the tabs, use a prying tool while pressing down on the back of the mouse. When prying, push the tab towards the outside of the mouse.
  4. Logitech M125 Button Plate Replacement: step 4, image 1 of 2 Logitech M125 Button Plate Replacement: step 4, image 2 of 2
    • To finish removing the button plate, continue lifting the rear of the plate until the tabs have fully left their slots.
    • Once the tabs are clear, push the plate towards the front of the mouse and lift.
  5. Logitech M125 Button Plate Replacement: step 5, image 1 of 1
    • The mouse button plate has now been fully removed. In order to install the replacement, follow the instructions for this guide in reverse.
Rob Myrick
267 Reputation
2 Guides authored
UW Tacoma, Team S1-G2, Liner Summer 2019 Member of UW Tacoma, Team S1-G2, Liner Summer 2019
UWT-LINER-SU19S1G2
5 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 789
