Logitech M215 Battery Replacement
  1. Logitech M215 Battery Replacement, Remove the battery cover: step 1, image 1 of 3 Logitech M215 Battery Replacement, Remove the battery cover: step 1, image 2 of 3 Logitech M215 Battery Replacement, Remove the battery cover: step 1, image 3 of 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Battery Replacement, Remove old battery: step 2, image 1 of 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
28 other people completed this guide.
Hannah Pate
1,742 Reputation
7 Guides authored
USF Tampa, Team 1-1, Watkins Winter 2015 Member of USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Members
28 Guides authored
10 Guide Comments
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - Reply
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - Reply
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - Reply
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - Reply
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - Reply
Past 24 Hours: 13
Past 7 Days: 86
Past 30 Days: 356
All Time: 122,645
