Logitech M215 Lens Replacement
  1. Logitech M215 Lens Replacement, Remove the battery cover: step 1, image 1 of 3 Logitech M215 Lens Replacement, Remove the battery cover: step 1, image 2 of 3 Logitech M215 Lens Replacement, Remove the battery cover: step 1, image 3 of 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Lens Replacement, Remove old battery: step 2, image 1 of 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Lens Replacement, Top Cover: step 3, image 1 of 2 Logitech M215 Lens Replacement, Top Cover: step 3, image 2 of 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Lens Replacement: step 4, image 1 of 1
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Lens Replacement, Motherboard: step 5, image 1 of 2 Logitech M215 Lens Replacement, Motherboard: step 5, image 2 of 2
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
  6. Logitech M215 Lens Replacement, Lens: step 6, image 1 of 2 Logitech M215 Lens Replacement, Lens: step 6, image 2 of 2
    • The laser amplifier is not connected to the rest of the mouse and can simply be removed at this point.
Hannah Pate
1,734 Reputation
7 Guides authored
USF Tampa, Team 1-1, Watkins Winter 2015 Member of USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Members
28 Guides authored
One Comment
Where i can buy mouse lenses for mk225
Cybermetz X - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 1,946
