Logitech M215 Motherboard Replacement
  1. Logitech M215 Motherboard Replacement, Remove the battery cover: step 1, image 1 of 3 Logitech M215 Motherboard Replacement, Remove the battery cover: step 1, image 2 of 3 Logitech M215 Motherboard Replacement, Remove the battery cover: step 1, image 3 of 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Motherboard Replacement, Remove old battery: step 2, image 1 of 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Motherboard Replacement, Top Cover: step 3, image 1 of 2 Logitech M215 Motherboard Replacement, Top Cover: step 3, image 2 of 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Motherboard Replacement: step 4, image 1 of 1
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Logitech M215 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
3 other people completed this guide.
Hannah Pate
1,734 Reputation
7 Guides authored
USF Tampa, Team 1-1, Watkins Winter 2015 Member of USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Members
28 Guides authored
3 Comments
bro whats the next step my guy
Jazmine Amaya - Reply
Hello,
Thanks a lot for this tutorial !
Where can I buy the motherboard for this wireless mouse?
Paolo - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 5,314
