Logitech MBJ58 Mouse Buttons Replacement
  1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: step 1, image 1 of 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Logitech MBJ58 Mouse Buttons Replacement: step 2, image 1 of 2 Logitech MBJ58 Mouse Buttons Replacement: step 2, image 2 of 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Logitech MBJ58 Mouse Buttons Replacement, Buttons: step 3, image 1 of 2 Logitech MBJ58 Mouse Buttons Replacement, Buttons: step 3, image 2 of 2
    • Locate the two tabs that are protruding from the button assembly.
    • Be careful not to break either of the two tabs by squeezing too hard.
    • Pinch the tabs together to free the buttons.
  4. Logitech MBJ58 Mouse Buttons Replacement: step 4, image 1 of 2 Logitech MBJ58 Mouse Buttons Replacement: step 4, image 2 of 2
    • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
    • Slide the button assembly out from the top cover through the opening.
    • When fully disassembled, the top cover and the button assembly should look like this.
2 other people completed this guide.
Maximilian Betkowski
235 Reputation
4 Guides authored
Cal Poly, Team 5-14, Forte Winter 2013 Member of Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 2,980
