Logitech MBJ58 Mouse Resistance Spring Replacement
  1. Logitech MBJ58 Mouse Resistance Spring Replacement, Top cover: step 1, image 1 of 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Logitech MBJ58 Mouse Resistance Spring Replacement: step 2, image 1 of 2 Logitech MBJ58 Mouse Resistance Spring Replacement: step 2, image 2 of 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 1 of 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 2 of 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 3 of 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: step 4, image 1 of 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: step 4, image 2 of 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: step 5, image 1 of 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: step 5, image 2 of 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 6, image 1 of 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 6, image 2 of 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 6, image 3 of 3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
  7. Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: step 7, image 1 of 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: step 7, image 2 of 2
    • Grasp the top of the resistance spring and pull it towards yourself, letting the hook slide out of its hole.
  8. Logitech MBJ58 Mouse Resistance Spring Replacement: step 8, image 1 of 1
    • Insert the hooked section of the replacement spring into the corresponding hole on the mount.
15 other people completed this guide.
Maximilian Betkowski
238 Reputation
4 Guides authored
Cal Poly, Team 5-14, Forte Winter 2013 Member of Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Members
23 Guides authored
10 Guide Comments
This mouse was also available from Dell as an OEM device under the model name "M-UVDEL1". Hopefully the Google juice will help folks repair their devices. I know I would have spent far more time than I did if it weren't for the photos on how to put the spring back. Thanks Maximilian!
Bastien Nocera - Reply
The spring installation details were lifesavers. Thank you!
LB
byard - Reply
thank you! could not have done it without your help.
taiyo_yuden_dvd - Reply
Brilliant. Thanks. Easy once you know how. The springs were the hard part.
Charles Thomson - Reply
Thank you so much!! You made it very easy and quick!
vulcanmeister - Reply
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 82
All Time: 12,762
