Logitech MX Keys Feet Replacement
  1. Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your keyboard.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
  2. Logitech MX Keys Feet Replacement, Remove the feet: step 2, image 1 of 2 Logitech MX Keys Feet Replacement, Remove the feet: step 2, image 2 of 2
    • Heat an iOpener and lay it on the top left foot for one minute.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic.
  3. Logitech MX Keys Feet Replacement: step 3, image 1 of 3 Logitech MX Keys Feet Replacement: step 3, image 2 of 3 Logitech MX Keys Feet Replacement: step 3, image 3 of 3
    • The foot should come up without much force. If it feels stuck, apply more heat and try again.
    • Insert the point of a spudger under an end of the foot.
    • Push the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it.
    • Repeat the process to remove the remaining feet.
    • If you're replacing the battery, you only need to remove the feet along the top edge.
  4. Logitech MX Keys Feet Replacement, Reassembly information: step 4, image 1 of 2 Logitech MX Keys Feet Replacement, Reassembly information: step 4, image 2 of 2
    Tool used on this step:
    Tesa 61395 Tape
    $2.99
    Buy
    • To install the feet during reassembly:
    • Use a pair of angled tweezers to peel up and remove all the plastic film from the foot recesses.
    • If you're installing new feet, remove them from their backing and firmly press them into place.
    • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
2 other people completed this guide.
Spencer Day
155,410 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
1 Guide Comment
Where do you buy replacement 'feet' for the MX Keys?
maxtraxpro - Reply
Past 24 Hours: 6
Past 7 Days: 59
Past 30 Days: 313
All Time: 4,035
