Logitech Slim Folio Battery Replacement
  1. Logitech Slim Folio Battery Replacement, Open the case: step 1, image 1 of 3 Logitech Slim Folio Battery Replacement, Open the case: step 1, image 2 of 3 Logitech Slim Folio Battery Replacement, Open the case: step 1, image 3 of 3
    • Open your case and lay it out flat.
  2. Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: step 2, image 1 of 3 Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: step 2, image 2 of 3 Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: step 2, image 3 of 3
    • Grip the two case corners closest to the keyboard with your thumbs and pull them down, away from the iPad.
    • Remove the iPad from the case.
  3. Logitech Slim Folio Battery Replacement, Locate the battery tray: step 3, image 1 of 2 Logitech Slim Folio Battery Replacement, Locate the battery tray: step 3, image 2 of 2
    • Fold the case in half, so the keyboard is facing up.
    • Locate the battery tray.
  4. Logitech Slim Folio Battery Replacement, Open the battery tray: step 4, image 1 of 3 Logitech Slim Folio Battery Replacement, Open the battery tray: step 4, image 2 of 3 Logitech Slim Folio Battery Replacement, Open the battery tray: step 4, image 3 of 3
    • Insert the pointed end of a spudger or a small screwdriver into the access hole on the battery tray.
    • Push the spudger in, down, and pull the spudger towards you.
    • The battery tray should "click" open.
  5. Logitech Slim Folio Battery Replacement, Remove the battery tray: step 5, image 1 of 2 Logitech Slim Folio Battery Replacement, Remove the battery tray: step 5, image 2 of 2
    • Insert the flat end of the spudger or a small flat head screwdriver into the top of the battery tray.
    • Push the battery tray out, away from the case, until you can grip it with your fingers.
    • If it's stuck, you may need to push on alternating sides to "walk" the tray out.
  6. Logitech Slim Folio Battery Replacement: step 6, image 1 of 2 Logitech Slim Folio Battery Replacement: step 6, image 2 of 2
    • Remove the battery tray.
  7. Logitech Slim Folio Battery Replacement, Remove the batteries: step 7, image 1 of 3 Logitech Slim Folio Battery Replacement, Remove the batteries: step 7, image 2 of 3 Logitech Slim Folio Battery Replacement, Remove the batteries: step 7, image 3 of 3
    • Flip the battery tray over.
    • Use the pointed end of the spudger to push both batteries out of the tray.
    • Remove the batteries.
  8. Logitech Slim Folio Battery Replacement, Reinstallation tip: step 8, image 1 of 3 Logitech Slim Folio Battery Replacement, Reinstallation tip: step 8, image 2 of 3 Logitech Slim Folio Battery Replacement, Reinstallation tip: step 8, image 3 of 3
    • To install new batteries:
    • Press one edge of a CR2032 coin cell battery against the contact arm, its text and "+" sign facing up.
    • Press to fully seat the battery.
    • Repeat for the second battery.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
49 other people completed this guide.
Carsten Frauenheim
156,622 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,829 Guides authored
21 Guide Comments
Excellent instructions. So easy - you made me a hero!
edspecial - Reply
So easy to do. I’m up and running again!
Susan Hallett - Reply
when you put the battery tray back in, you have to push it kind of hard to get it to go all the way in. I didn’t have a spudger but was able to use an ice pick (gently) and then a small flat screw driver.
pdmd - Reply
What if you don’t have a spider? Is there anything else that you can use to open the battery tray?
Kathy Pecsko - Reply
You can use something pointy instead of a Spudger. For example: A pair of scissors ✂️. You can open them with the pointy blade. Thanks!
Cheryl Xu -
Past 24 Hours: 157
Past 7 Days: 1,007
Past 30 Days: 4,636
All Time: 328,759
