Logitech UE MegaBoom 3 Battery Replacement
  1. Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: step 1, image 1 of 2 Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: step 1, image 2 of 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Battery Replacement: step 2, image 1 of 3 Logitech UE MegaBoom 3 Battery Replacement: step 2, image 2 of 3 Logitech UE MegaBoom 3 Battery Replacement: step 2, image 3 of 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Battery Replacement, Battery: step 3, image 1 of 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: step 3, image 2 of 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the lithium-ion battery from the inside of the speaker by gripping the battery using the plyers.
    • Here, it is ideal to use a tweezers as opposed to the plyers, however, the plyers makes it so much easier to take out the battery.
    • The battery should slide out as you pull against it with the plyers.
    • Remove the battery.
4 other people completed this guide.
Jason Doland
124 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 152
All Time: 2,653
