Logitech UE MegaBoom 3 Motherboard Replacement
  1. Logitech UE MegaBoom 3 Motherboard Replacement, General Disassembly: step 1, image 1 of 2 Logitech UE MegaBoom 3 Motherboard Replacement, General Disassembly: step 1, image 2 of 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Motherboard Replacement: step 2, image 1 of 3 Logitech UE MegaBoom 3 Motherboard Replacement: step 2, image 2 of 3 Logitech UE MegaBoom 3 Motherboard Replacement: step 2, image 3 of 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Motherboard Replacement, Power Button Control Board: step 3, image 1 of 3 Logitech UE MegaBoom 3 Motherboard Replacement, Power Button Control Board: step 3, image 2 of 3 Logitech UE MegaBoom 3 Motherboard Replacement, Power Button Control Board: step 3, image 3 of 3
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Motherboard Replacement: step 4, image 1 of 3 Logitech UE MegaBoom 3 Motherboard Replacement: step 4, image 2 of 3 Logitech UE MegaBoom 3 Motherboard Replacement: step 4, image 3 of 3
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Motherboard Replacement: step 5, image 1 of 3 Logitech UE MegaBoom 3 Motherboard Replacement: step 5, image 2 of 3 Logitech UE MegaBoom 3 Motherboard Replacement: step 5, image 3 of 3
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
  6. Logitech UE MegaBoom 3 Motherboard Replacement, Speaker Driver: step 6, image 1 of 2 Logitech UE MegaBoom 3 Motherboard Replacement, Speaker Driver: step 6, image 2 of 2
    • Take of the metal rods by gently prying them out using the metal spudger.
    • Be sure to slide them out as gently as possible to prevent the rods from becoming damaged.
  7. Logitech UE MegaBoom 3 Motherboard Replacement: step 7, image 1 of 2 Logitech UE MegaBoom 3 Motherboard Replacement: step 7, image 2 of 2
    • Once the rods are removed, you can pry it off and disconnect the speaker driver.
    • Repeat the same steps to disconnect the speaker driver on the other side of the speaker.
  8. Logitech UE MegaBoom 3 Motherboard Replacement, Passive Radiator: step 8, image 1 of 2 Logitech UE MegaBoom 3 Motherboard Replacement, Passive Radiator: step 8, image 2 of 2
    • Take off the metal rods by gently prying them out using the metal spudgers
  9. Logitech UE MegaBoom 3 Motherboard Replacement: step 9, image 1 of 1
    • One the rods are removed you can pry it off and disconnect the passive radiator.
    • Repeat the same steps to disconnect the passive radiator on the other side of the speaker.
  10. Logitech UE MegaBoom 3 Motherboard Replacement, Motherboard: step 10, image 1 of 3 Logitech UE MegaBoom 3 Motherboard Replacement, Motherboard: step 10, image 2 of 3 Logitech UE MegaBoom 3 Motherboard Replacement, Motherboard: step 10, image 3 of 3
    • Using the metal spudger, remove the volume control board to prevent any damage.
    • Remove the clear silicone cover to access the board.
    • Carefully pull off the board and disconnect it from the motherboard.
  11. Logitech UE MegaBoom 3 Motherboard Replacement: step 11, image 1 of 2 Logitech UE MegaBoom 3 Motherboard Replacement: step 11, image 2 of 2
    • Slide out the mother board gently.
3 other people completed this guide.
Anthony Miles
981 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 36
All Time: 249
