Logitech UE MegaBoom Outer Mesh Replacement
  1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: step 1, image 1 of 3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: step 1, image 2 of 3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: step 1, image 3 of 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Outer Mesh Replacement: step 2, image 1 of 3 Logitech UE MegaBoom Outer Mesh Replacement: step 2, image 2 of 3 Logitech UE MegaBoom Outer Mesh Replacement: step 2, image 3 of 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Outer Mesh Replacement: step 3, image 1 of 2 Logitech UE MegaBoom Outer Mesh Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
Oscar Ambriz
977 Reputation
6 Guides authored
Cal Poly, Team S9-G2, Banghart Fall 2017 Member of Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Members
17 Guides authored
2 Guide Comments
You know where to buy a replacement mesh in custom colors
Jonathan Lang - Reply
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Evan Castione - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 4,593
