Logitech Webcam Pro 9000 Front and Back Cover Replacement
  1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: step 1, image 1 of 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: step 1, image 2 of 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Front and Back Cover Replacement: step 2, image 1 of 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement: step 2, image 2 of 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
Timothy Forrest
19 Reputation
2 Guides authored
Cal Poly, Team 12-34, Amido Spring 2013 Member of Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,262
