Logitech Webcam Pro 9000 Microphone Replacement
  1. Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: step 1, image 1 of 2 Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: step 1, image 2 of 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Microphone Replacement: step 2, image 1 of 2 Logitech Webcam Pro 9000 Microphone Replacement: step 2, image 2 of 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: step 3, image 1 of 2 Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: step 3, image 2 of 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  4. Logitech Webcam Pro 9000 Microphone Replacement, Microphone: step 4, image 1 of 3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: step 4, image 2 of 3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: step 4, image 3 of 3
    • Wedge the plastic opening tool into the crack between the plastic cover and microphone guard.
    • Use the wedge to separate the two pieces.
    • It might take more force than expected.
  5. Logitech Webcam Pro 9000 Microphone Replacement: step 5, image 1 of 3 Logitech Webcam Pro 9000 Microphone Replacement: step 5, image 2 of 3 Logitech Webcam Pro 9000 Microphone Replacement: step 5, image 3 of 3
    • Twist the rubber casing and remove it from the plastic cover.
2 other people completed this guide.
nieko
63 Reputation
2 Guides authored
Cal Poly, Team 12-34, Amido Spring 2013 Member of Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 10
All Time: 2,246
