Logitech Webcam Pro 9000 Motherboard Replacement
  1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: step 1, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: step 1, image 2 of 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Motherboard Replacement: step 2, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement: step 2, image 2 of 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: step 3, image 1 of 3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: step 3, image 2 of 3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: step 3, image 3 of 3
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
  4. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: step 4, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: step 4, image 2 of 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  5. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: step 5, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  6. Logitech Webcam Pro 9000 Motherboard Replacement: step 6, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement: step 6, image 2 of 2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  7. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: step 7, image 1 of 1
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  8. Logitech Webcam Pro 9000 Motherboard Replacement: step 8, image 1 of 3 Logitech Webcam Pro 9000 Motherboard Replacement: step 8, image 2 of 3 Logitech Webcam Pro 9000 Motherboard Replacement: step 8, image 3 of 3
    • Remove the camera from the motherboard by desoldering the two connections as shown.
Cory Davis
236 Reputation
4 Guides authored
Cal Poly, Team 12-34, Amido Spring 2013 Member of Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 2,112
