Logitech Z4 Desk Speaker Disassembly
  1. Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: step 1, image 1 of 3 Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: step 1, image 2 of 3 Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: step 1, image 3 of 3
    • Use a PH2 screwdriver to remove the two screws on the back of the speaker.
    • the speaker has a cinch connector to plug in to the sub-woofer.
  2. Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: step 2, image 1 of 2 Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: step 2, image 2 of 2
    • removing the decorative front panel with a plastic pick (guitar picks work great). it is quite sturdy but the adhesive film on the back of it is strong, so go slow or heat it up with a hairdryer.
  3. Logitech Z4 Desk Speaker Disassembly, Removing the housing screws: step 3, image 1 of 1
    • removing the main screws for the speaker housing. using the same driver (PH2) we can remove the 8 screws holding the main speaker assembly together.
  4. Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: step 4, image 1 of 2 Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: step 4, image 2 of 2
    • opening the speaker housing by prying it up evenly on all sides with the plastic pick.
    • it can be tapped lightly on the desk to make it fall out at the end of the process.
  5. Logitech Z4 Desk Speaker Disassembly, Taking inventory: step 5, image 1 of 3 Logitech Z4 Desk Speaker Disassembly, Taking inventory: step 5, image 2 of 3 Logitech Z4 Desk Speaker Disassembly, Taking inventory: step 5, image 3 of 3
    • after opening the speaker fully you can see that the top and bottom membranes are not speakers, only decoration.
    • the middle one is connected with two wires matching the cinch connector on the cable.
    • the cable has a screw and some hot glue acting as a strain release for the cable.
5 other people completed this guide.
kugelzucker
315 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 68
All Time: 2,428
