Longboard or Skateboard Truck Maintenance
  1. Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: step 1, image 1 of 2 Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: step 1, image 2 of 2
    • Use a Phillips/flat head screw driver, along with a skate tool or set of pliers, to loosen the nuts which fasten the trucks to the deck.
  2. Longboard or Skateboard Truck Maintenance: step 2, image 1 of 1
    • Use your fingers to fully loosen and remove the nuts from the bolts.
    • Nuts are small and easy to lose track of.
  3. Longboard or Skateboard Truck Maintenance: step 3, image 1 of 3 Longboard or Skateboard Truck Maintenance: step 3, image 2 of 3 Longboard or Skateboard Truck Maintenance: step 3, image 3 of 3
    • Use your hands to remove the trucks from the deck.
    • Make sure the kingpin is facing outward, If the kingpin is not properly reinstalled, the trucks will fail to perform properly.
  4. Longboard or Skateboard Truck Maintenance: step 4, image 1 of 1
    • Remove the truck raiser if applicable.
  5. Longboard or Skateboard Truck Maintenance: step 5, image 1 of 2 Longboard or Skateboard Truck Maintenance: step 5, image 2 of 2
    • Remove the bolts from the factory drilled holes on the deck.
    • Note that the bolts are small and easy to lose track of.
  6. Longboard or Skateboard Truck Maintenance: step 6, image 1 of 1
    • Clean the deck with a moist cloth or cleaning solution.
  7. Longboard or Skateboard Truck Maintenance: step 7, image 1 of 1
    • Clean the trucks with a moist cloth or cleaning solution.
  8. Longboard or Skateboard Truck Maintenance: step 8, image 1 of 2 Longboard or Skateboard Truck Maintenance: step 8, image 2 of 2
    • Clean the hardware by either soaking it in cleaning solution, or by manually cleaning it with a moist cloth.
  9. Longboard or Skateboard Truck Maintenance: step 9, image 1 of 1
    • Repeat steps 1-7 with the second truck.
  10. Longboard or Skateboard Truck Maintenance: step 10, image 1 of 1
    • After re-installation, check and confirm that all the bolts and nuts are tight. The bolts should be slightly submerged in the wood of the deck
    • Over tightening the bolts can cause them to strip.
    • Failure to tighten the bolts and nuts properly may lead to improper performance.
  11. Longboard or Skateboard Truck Maintenance: step 11, image 1 of 2 Longboard or Skateboard Truck Maintenance: step 11, image 2 of 2
    • After re-installing the trucks, check and confirm the kingpin is facing outward.
    • Failure to do this will cause the longboard's functions to be inverted, which may lead to personal injury.
Now you’ve completed the guide ‘How to clean and maintain skate/longboard trucks. Your longboard should look like the picture. Before riding, as a final precaution, make sure every piece is securely fastened and the trucks are facing the correct way. Have fun and always wear a helmet!
Dominic Turano
122 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 7,477
