Lorex LW2742 Night Vision IR LEDs Replacement
  1. Lorex LW2742 Night Vision IR LEDs Replacement, Night Vision IR LEDs: step 1, image 1 of 2 Lorex LW2742 Night Vision IR LEDs Replacement, Night Vision IR LEDs: step 1, image 2 of 2
    • Remove the six 10mm Torx T10 screws on the camera face.
  2. Lorex LW2742 Night Vision IR LEDs Replacement: step 2, image 1 of 1
    • Remove the exterior lens cover.
  3. Lorex LW2742 Night Vision IR LEDs Replacement: step 3, image 1 of 3 Lorex LW2742 Night Vision IR LEDs Replacement: step 3, image 2 of 3 Lorex LW2742 Night Vision IR LEDs Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Night Vision IR LEDs Replacement: step 4, image 1 of 2 Lorex LW2742 Night Vision IR LEDs Replacement: step 4, image 2 of 2
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the top and bottom 5mm screws first, followed by the left and right 8mm screws.
  5. Lorex LW2742 Night Vision IR LEDs Replacement: step 5, image 1 of 2 Lorex LW2742 Night Vision IR LEDs Replacement: step 5, image 2 of 2
    • Use tweezers to unclip the cables to the LED board
craig crisci
220 Reputation
1 Guide authored
USF Tampa, Team 16-1, Eyestone Fall 2016 Member of USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,032
