Lorex LW2742 Speaker Replacement
  1. Lorex LW2742 Speaker Replacement, Back Panel: step 1, image 1 of 3 Lorex LW2742 Speaker Replacement, Back Panel: step 1, image 2 of 3 Lorex LW2742 Speaker Replacement, Back Panel: step 1, image 3 of 3
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. Lorex LW2742 Speaker Replacement: step 2, image 1 of 1
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  3. Lorex LW2742 Speaker Replacement: step 3, image 1 of 2 Lorex LW2742 Speaker Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
  4. Lorex LW2742 Speaker Replacement, Speaker: step 4, image 1 of 3 Lorex LW2742 Speaker Replacement, Speaker: step 4, image 2 of 3 Lorex LW2742 Speaker Replacement, Speaker: step 4, image 3 of 3
    • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
  5. Lorex LW2742 Speaker Replacement: step 5, image 1 of 2 Lorex LW2742 Speaker Replacement: step 5, image 2 of 2
    • Using a metal spudger, pry the melted black plastic away from the speaker.
    • Carefully pull the speaker out of its housing by the wires.
Alex Kusmierz
601 Reputation
5 Guides authored
USF Tampa, Team 16-1, Eyestone Fall 2016 Member of USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 221
