Lubricate General Electric Telephone 2-9710A Power Dial
  1. Lubricate General Electric Telephone 2-9710A Power Dial, Phone Cord: step 1, image 1 of 2 Lubricate General Electric Telephone 2-9710A Power Dial, Phone Cord: step 1, image 2 of 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Lubricate General Electric Telephone 2-9710A Power Dial: step 2, image 1 of 3 Lubricate General Electric Telephone 2-9710A Power Dial: step 2, image 2 of 3 Lubricate General Electric Telephone 2-9710A Power Dial: step 2, image 3 of 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Lubricate General Electric Telephone 2-9710A Power Dial, 9V Base Battery: step 3, image 1 of 2 Lubricate General Electric Telephone 2-9710A Power Dial, 9V Base Battery: step 3, image 2 of 2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Lubricate General Electric Telephone 2-9710A Power Dial, Remove Volume Dial: step 4, image 1 of 2 Lubricate General Electric Telephone 2-9710A Power Dial, Remove Volume Dial: step 4, image 2 of 2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Lubricate General Electric Telephone 2-9710A Power Dial, Remove Screws on the Back: step 5, image 1 of 1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Lubricate General Electric Telephone 2-9710A Power Dial, Pry the Back Off: step 6, image 1 of 2 Lubricate General Electric Telephone 2-9710A Power Dial, Pry the Back Off: step 6, image 2 of 2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. Lubricate General Electric Telephone 2-9710A Power Dial, Lubricate General Electric Telephone 2-9710A Power Dial: step 7, image 1 of 1
    • Inside the base shell on the circuit board, lubricate the power switch.
    • Make sure the lubricant does not get on the circuit board. This can damage the circuit board.
Norberto Sanchez
70 Reputation
5 Guides authored
Cal Poly, Team 16-59, Forte Fall 2012 Member of Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 895
