Lunii - My Story Factory v2 - Rotary Encoder Replacement
  1. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Unscrew the screws: step 1, image 1 of 1
    • Remove the 4 Torx 6 screws located at the back of the device.
    • Since the screws are housed at the bottom of a hole, you will need a particularly long bit or even better, a screwdriver.
  2. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Open the box: step 2, image 1 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Open the box: step 2, image 2 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Open the box: step 2, image 3 of 3
    • Separate the two parts of the box, taking care to open the box well from the top, so that you end up with the contents of the box still in place in each of the halves.
  3. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Remove the battery from its housing.: step 3, image 1 of 2 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Remove the battery from its housing.: step 3, image 2 of 2
    • Remove the battery from its housing.
  4. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Disconnect the battery: step 4, image 1 of 2 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Disconnect the battery: step 4, image 2 of 2
    • The connector needs to be removed very gently.
    • Depending on the connector, some force may be required.
  5. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Selection Knob Removal: step 5, image 1 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Selection Knob Removal: step 5, image 2 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Selection Knob Removal: step 5, image 3 of 3
    • Remove the selection knob by pulling it upwards.
    • For reassembly, there's a small pin on one side of the knob axis which must match that of the component on the PCB.
  6. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Lift the screen to reach the connector: step 6, image 1 of 2 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Lift the screen to reach the connector: step 6, image 2 of 2
    • Lift the screen to reach the connector.
  7. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Unplug the screen: step 7, image 1 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Unplug the screen: step 7, image 2 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Unplug the screen: step 7, image 3 of 3
    • Unplug the screen by opening the connector and sliding the ribbon cable out.
    • To open the connector, slide it to the left.
    • If the ribbon cable doesn't come out of the connector freely, there's no need to force it - it's just that the connector isn't open enough.
  8. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Remove the speaker from its housing: step 8, image 1 of 2 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Remove the speaker from its housing: step 8, image 2 of 2
    • Remove the speaker from its housing.
  9. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Unplug the speaker: step 9, image 1 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Unplug the speaker: step 9, image 2 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Unplug the speaker: step 9, image 3 of 3
    • The connector just needs to be carefully removed.
    • Depending on the connector, a certain amount of force may be required.
  10. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Volume dial removal: step 10, image 1 of 2 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Volume dial removal: step 10, image 2 of 2
    • Remove the volume dial by pulling it out.
    • The knob has a latch, which must be returned to its original position when reassembling.
  11. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Circuit board removal: step 11, image 1 of 2 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Circuit board removal: step 11, image 2 of 2
    • The circuit board is easy to remove from the case, as there are no screws to hold it in place.
  12. Lunii - My Story Factory v2 - Rotary Encoder Replacement, Resolder the encoder: step 12, image 1 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Resolder the encoder: step 12, image 2 of 3 Lunii - My Story Factory v2 - Rotary Encoder Replacement, Resolder the encoder: step 12, image 3 of 3
    • Reposition the encoder and re-solder each of the pins.
    • It's not always easy to do, and you need to be very careful with the small resistors and capacitors around them, so as not to move or burn them.
    • Make sure the component is correctly oriented, and do not reassemble it upside down; 0 must face the battery connector.
    • If you use another compatible replacement component, pin details are shown in the last image.
To reassemble your device, follow the steps in reverse.
6 other people completed this guide.
Special thanks to these translators:
fr en
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
Benoit74
3,107 Reputation
11 Guides authored
16 Comments
Merci pour le tuto je l'ai fait mais j'ai un pad du circuit imprimé qui s'est décollé du circuit et qui est en train de céder... Savez vous a quoi sont ils raccorder que je face un pont ?
Benvey - Reply
Merci, je viens d'ajouter un schéma électronique de cette partie du circuit sur la dernière étape. En gros, il suffit de faire un pont vers l'espace entre le condensateur et la résistance les plus proches (qui sont déjà reliés entre eux).
Benoit74 -
Bonjour,
J'ai acheter un encodeur de la référence qui m'a été donner par lunii, mais quand je l'ai soudé, le codage ne correspond pas.
La Lunii ne fait pas un cycle des histoires, si l'on tourne d'un coté on a 2 ou 3 histoire (avec de la change une 4ieme est sélectionnée). Même chose de l'autre coté avec des histoires différentes.
Y a t-il une possibilité de modifier le code de la lunii?
Merci pour le coup de main.
Juju_ - Reply
Bonjour,
Je ne sais pas modifier le code de la Lunii, sans doute faisable mais sûrement pas simple.
Je ne suis pas non plus sûr que cela soit nécessaire, il est à mon avis plus probable que votre réparation ne soit pas totalement fonctionnelle. Avez-vous vérifié (batterie débranchée) qu'il y a bien une résistance de 10kOhm (environ) entre chacune des 4 pattes extérieures de l'encodeur et le 3.3V ? Qu'il y a bien une continuité entre chacune des deux pattes du milieu de l'encodeur et la masse ? (cf. schéma sur la dernière étape pour les détails).
Benoit74 -
Bonjour,
L’encodeur de celle de mon fils avait déjà des hoquets avant une dégringolade d’escaliers... je pensais qu’une patte était déconnectée pour expliquer les ratés, après la chute la panne était plus franche au moins : toutes les pattes étaient cassées !
Un point de colle chaude sous l’encodeur (ouais vu ce qu’il restait des pattes, il me fallait de l’aide pour le tenir en place !) et 6 soudures plus tard, elle marchait comme avant la chute :-|
Grâce à cet échange, j’ai pu confirmer que c’est l’encodeur qui doit être usé, j’ai bien ~10kOhms entre les pattes des coins et une borne de la batterie (après, je ne sais pas si c’est normal mais j’ai un côté de l’encodeur qui a cette résistance avec une patte de la batterie et l’autre côté avec l’autre patte...).
C’est déjà pas mal et nous permet de survivre mais je pense qu’il me faut donc remplacer cet encodeur !
J’ai vu 2 ref sur un fil qui parle de la V1, c’est le même modèle sur la V2 ?
Namu -
Past 24 Hours: 27
Past 7 Days: 197
Past 30 Days: 776
All Time: 5,835
