M3D Micro Fan Replacement
  1. M3D Micro Fan Replacement, Fan: step 1, image 1 of 3 M3D Micro Fan Replacement, Fan: step 1, image 2 of 3 M3D Micro Fan Replacement, Fan: step 1, image 3 of 3
    • To release the x-rods, pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks.
  2. M3D Micro Fan Replacement: step 2, image 1 of 3 M3D Micro Fan Replacement: step 2, image 2 of 3 M3D Micro Fan Replacement: step 2, image 3 of 3
    • Slide the tracks off the second slider and remove the printer head and x-tracks from the center of the printer. To remove the front cover of the print head, firmly grip the cover and gently pull it off.
  3. M3D Micro Fan Replacement: step 3, image 1 of 2 M3D Micro Fan Replacement: step 3, image 2 of 2
    • Disconnect the red and black wires at the white connector. They should easily separate.
  4. M3D Micro Fan Replacement: step 4, image 1 of 3 M3D Micro Fan Replacement: step 4, image 2 of 3 M3D Micro Fan Replacement: step 4, image 3 of 3
    • The fan is held loosely in place at the base of the printer head. Use a metal spudger to gently pry it out of the printer head.
  5. M3D Micro Fan Replacement: step 5, image 1 of 1
    • Pull the fan all the way out of the printer head.
Yuliya Marusyk
285 Reputation
2 Guides authored
USF Tampa, Team S3-G2, Nance Fall 2017 Member of USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 1,384
