M3D Micro Motor Replacement
  1. M3D Micro Motor Replacement, M3D Micro Frame Removal: step 1, image 1 of 1
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Motor Replacement: step 2, image 1 of 3 M3D Micro Motor Replacement: step 2, image 2 of 3 M3D Micro Motor Replacement: step 2, image 3 of 3
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
    I could get it loose on one side. The other is firmly stuck. It does let me flip the head up to the side, but it won’t come loose without significant violence.
    Also, to the the first one loose, I have to pull the Y-rods so hard that they bend. Not plastic deformation, they are not ruined (I think) but the amount of force disturbs me.
    Ragnemalm - Reply
  3. M3D Micro Motor Replacement: step 3, image 1 of 2 M3D Micro Motor Replacement: step 3, image 2 of 2
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
    This doesn’t work at all on my M3D. I had to force in a tool, a kitchen knife, to crack it open in each corner. THEN I can lift it up. (But I still can’t lift it off since I can’t remove the printer head. More force needed there.)
    Reassembly is harder, because you have six rods that must get into separate holes more or less simultaneously, and I guess those small metal rings on the top have a purpose too.
    Ragnemalm - Reply
  4. M3D Micro Motor Replacement, Motor: step 4, image 1 of 1
    • Once the base is opened you should find a circuit board and two motors like the one on the right, select the motor to be replaced.
    You forgot one step: How to remove the base!
    Ragnemalm - Reply
  5. M3D Micro Motor Replacement: step 5, image 1 of 2 M3D Micro Motor Replacement: step 5, image 2 of 2
    • Unplug the connectors for the Orange, Blue, Gray and Black cables. These would be the motor cables.
  6. M3D Micro Motor Replacement: step 6, image 1 of 2 M3D Micro Motor Replacement: step 6, image 2 of 2
    • Once disconnected you will proceed to lift the motor using pliers.
  7. M3D Micro Motor Replacement: step 7, image 1 of 2 M3D Micro Motor Replacement: step 7, image 2 of 2
    • Now, remove the motor.
Miguel Pina
122 Reputation
1 Guide authored
USF Tampa, Team S3-G2, Nance Fall 2017 Member of USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Members
10 Guides authored
One Comment
Hello, good work and explanation. Is there any possibility to replace MICRO+ X-AXIS MOTOR “gear” please. Thanks
robozeka - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,711
