M3t Kiosk Preventative maintenance
  1. M3t Kiosk  Preventative maintenance, Handle and Lock: step 1, image 1 of 1
    • Make sure the door lock and handle are in good working order and not bent or loose
  2. M3t Kiosk  Preventative maintenance, Opt cords: step 2, image 1 of 2 M3t Kiosk  Preventative maintenance, Opt cords: step 2, image 2 of 2
    • Check the opt cords to make sure they aren’t broken or crimped
  3. M3t Kiosk  Preventative maintenance, Opt Lights: step 3, image 1 of 1
    • Make sure all the opt box lights that are supposed to be on are on.
  4. M3t Kiosk  Preventative maintenance, Dispenser Belts: step 4, image 1 of 2 M3t Kiosk  Preventative maintenance, Dispenser Belts: step 4, image 2 of 2
    • Clean belts on top and on the back of the dispenser.
  5. M3t Kiosk  Preventative maintenance, Test Dispense: step 5, image 1 of 3 M3t Kiosk  Preventative maintenance, Test Dispense: step 5, image 2 of 3 M3t Kiosk  Preventative maintenance, Test Dispense: step 5, image 3 of 3
    • Test dispense the coin hoppers and the cash dispenser
  6. M3t Kiosk  Preventative maintenance, Test Dispense (continued): step 6, image 1 of 2 M3t Kiosk  Preventative maintenance, Test Dispense (continued): step 6, image 2 of 2
    • (Continued)
  7. M3t Kiosk  Preventative maintenance: step 7, image 1 of 1
    • Check the coin hoppers to make sure nothing is in it other than coins (like rubber bands or something that was dropped in it)
  8. M3t Kiosk  Preventative maintenance, Fans: step 8, image 1 of 2 M3t Kiosk  Preventative maintenance, Fans: step 8, image 2 of 2
    • Clean any dust off of the fans
  9. M3t Kiosk  Preventative maintenance, Printer: step 9, image 1 of 1
    • Check the printer for paper and put in more if it's needed
  10. M3t Kiosk  Preventative maintenance: step 10, image 1 of 2 M3t Kiosk  Preventative maintenance: step 10, image 2 of 2
    • Open and blow out the printer to remove any loose paper
  11. M3t Kiosk  Preventative maintenance, Clean Bill Validator: step 11, image 1 of 1
    • Run a cleaning strip through the BV
  12. M3t Kiosk  Preventative maintenance, Bill Validator board: step 12, image 1 of 1
    • Check for coins on the BV board.
  13. M3t Kiosk  Preventative maintenance, Bill Validator protector: step 13, image 1 of 1
    • Put a board protector on if it’s missing and you have one available
  14. M3t Kiosk  Preventative maintenance, Screen cleaning: step 14, image 1 of 1
    • Clean the touch screen
  15. M3t Kiosk  Preventative maintenance, Door lights: step 15, image 1 of 1
    • Check to see if the door lights are on and working
2 other people completed this guide.
Timothy Morse
1,198 Reputation
6 Guides authored
The Curo Group Member of The Curo Group
Community
2 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 274
