MAGNAVOX MDV2300 Power Cord Replacement
  1. MAGNAVOX MDV2300 Power Cord Replacement, Power Cord: step 1, image 1 of 1
    • Make sure the device is unplugged from the wall.
  2. MAGNAVOX MDV2300 Power Cord Replacement: step 2, image 1 of 1
    • Unscrew the two screws that hold together the top panel.
  3. MAGNAVOX MDV2300 Power Cord Replacement: step 3, image 1 of 1
    • Remove the top panel.
  4. MAGNAVOX MDV2300 Power Cord Replacement: step 4, image 1 of 1
  5. MAGNAVOX MDV2300 Power Cord Replacement: step 5, image 1 of 2 MAGNAVOX MDV2300 Power Cord Replacement: step 5, image 2 of 2
    • Remove disc drive by unscrewing the 2 screws that hold the drive in place.
  6. MAGNAVOX MDV2300 Power Cord Replacement: step 6, image 1 of 1
    • Identify the power cord.
    • The cord must either be too short or torn to warrant replacement.
  7. MAGNAVOX MDV2300 Power Cord Replacement: step 7, image 1 of 1
    • Cut the old wire out from the chip.
    • Attach the new wire into the housing.
    • Line up new wire with the appropriate holes and solder to board.
    • The white wire will be your neutral and the black wire will be your negative. View link of how to solder in order to replace the power cord. http://www.instructables.com/id/How-to-s...
After soldering, let cool and then reassemble your device, follow these instructions in reverse order.
Justin
298 Reputation
2 Guides authored
Penn State, Team 1-41, Kaschak Winter 2015 Member of Penn State, Team 1-41, Kaschak Winter 2015
PSU-KASCHAK-W15S1G41
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 534
