MARCO UP Series Pump Disassembly
  1. MARCO UP Series Pump Disassembly, Remove the top plate: step 1, image 1 of 3 MARCO UP Series Pump Disassembly, Remove the top plate: step 1, image 2 of 3 MARCO UP Series Pump Disassembly, Remove the top plate: step 1, image 3 of 3
    • Put the pump on the table, heading up.
    • Unscrew the 4 screws with the screwdriver.
    • Remove the O-ring.
  2. MARCO UP Series Pump Disassembly, Remove the Gears: step 2, image 1 of 3 MARCO UP Series Pump Disassembly, Remove the Gears: step 2, image 2 of 3 MARCO UP Series Pump Disassembly, Remove the Gears: step 2, image 3 of 3
    • Using the flat head screwdriver apply some force between two teeth and try to lift the gear. Use the other hand or a plier (usually you don't need it) to take the first gear away.
    • Remove the second gear.
    • Remove the key, with the help of the flat head screwdriver: try to raise it from the bottom.
    • Don't forget to remove the key! If you do, you won't be able to continue.
  3. MARCO UP Series Pump Disassembly, Unscrew the nuts on the back: step 3, image 1 of 2 MARCO UP Series Pump Disassembly, Unscrew the nuts on the back: step 3, image 2 of 2
    • Unscrew the nuts on the back using the socket wrench screwdriver.
    • Take away the washer and the little O-rings.
  4. MARCO UP Series Pump Disassembly, Lift the pump's body: step 4, image 1 of 3 MARCO UP Series Pump Disassembly, Lift the pump's body: step 4, image 2 of 3 MARCO UP Series Pump Disassembly, Lift the pump's body: step 4, image 3 of 3
    • Keep your thumb on the shaft and lift the pump's head pulling from the hosefittings.
    • Then, again, keep your thumb on the shaft and lift the motor's stator.
    • Be careful: the magnetic field is strong, your finger may squeeze between the parts!
  5. MARCO UP Series Pump Disassembly, Take out the rotor from the stator case: step 5, image 1 of 3 MARCO UP Series Pump Disassembly, Take out the rotor from the stator case: step 5, image 2 of 3 MARCO UP Series Pump Disassembly, Take out the rotor from the stator case: step 5, image 3 of 3
    • If the rotor gets stuck in the stator, push it from the bottom and pull it from the other side.
    • You need to have them separated, to assembly those back again.
    • You can now pull out the bearing and the spring from the back plate, using the flat screwdriver or the rotor shaft.
  6. MARCO UP Series Pump Disassembly, The disassembly is complete: step 6, image 1 of 1
    • These are the pieces that you've just disassembled.
If you need to assemble the pump, use this guide: Marco UP Series Electric Pump Assembly
8 other people completed this guide.
Marco Spa
1,501 Reputation
5 Guides authored
4 Comments
Domanda stupida: la pompa riceve corrente,gli ingranaggi (smontando la parte che li contiene) girano con una minima sollecitazione) il fusibile non salta…ma la pompa non parte! che faccio? …sono in grecia e volevo provare a sbloccarla prima di darmi battuto Grazie stefano
cippura - Reply
Buongiorno,
se il motore parte (si muove) ma la pompa non muove acqua, sembrerebbe che le manchi la “chiavetta” che trasmette il moto dell’albero all’ingranaggio (passaggio 2 della guida). Nel caso non fosse questo il problema o volesse acquistare una nuova chiavetta, le suggerisco di scrivere a support@marco.it per una gestione diretta del problema con l’azienda e i loro tecnici.
Matteo -
Привет! Где купить сальник и подшипник для Marco up6 напишите ответ на почту igorandreev_1@mail.ru
igorandreev_1 - Reply
Привет! Вы можете найти все запасные части на нашем сайте www.marco.it ( https://items.marco.it/en/r6400094.html ). Вы можете купить их оттуда после регистрации.
Marco Spa -
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 83
All Time: 5,554
