MJS T2702 Screen Replacement
  1. MJS T2702 Screen Replacement, Battery: step 1, image 1 of 2 MJS T2702 Screen Replacement, Battery: step 1, image 2 of 2
    • Separate the back of the device from the face by inserting the flat end of the nylon spudger into the corner of the device to safely pry it open.
  2. MJS T2702 Screen Replacement: step 2, image 1 of 1
    • Use the nylon spudger to gently pry out the battery.
  3. MJS T2702 Screen Replacement: step 3, image 1 of 1
  4. MJS T2702 Screen Replacement, Screen: step 4, image 1 of 1
    • Remove the 4.1 mm screws from the motherboard using the J #000 Phillips Screwdriver.
  5. MJS T2702 Screen Replacement: step 5, image 1 of 1
    • Carefully remove the tape connected to the back of the screen and the motherboard.
  6. MJS T2702 Screen Replacement: step 6, image 1 of 1
    • Use the nylon spudger to separate the screen from the plastic casing.
Katalina Benecke
364 Reputation
3 Guides authored
Texas Tech, Team 1-13, Bennett Fall 2016 Member of Texas Tech, Team 1-13, Bennett Fall 2016
TTU-BENNETT-F16S1G13
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 311
