MNT Reform Bottom Plate Replacement
  1. MNT Reform Bottom Plate Replacement, Remove Bottom Plate Screws: step 1, image 1 of 1
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
  2. MNT Reform Bottom Plate Replacement, Remove Bottom Plate: step 2, image 1 of 1
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Neelfyn
981 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 16
All Time: 418
