MNT Reform SSD Replacement
  1. MNT Reform SSD Replacement, Remove Bottom Plate Screws: step 1, image 1 of 1
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
  2. MNT Reform SSD Replacement, Remove Bottom Plate: step 2, image 1 of 1
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
  3. MNT Reform SSD Replacement, Remove Battery Cells: step 3, image 1 of 2 MNT Reform SSD Replacement, Remove Battery Cells: step 3, image 2 of 2
    • Pull out the eight battery cells one by one, and set them aside safely.
    • Do not use a metal tool to remove the batteries. You may accidentally short-circuit the metal pins of the battery holders.
    • When replacing the batteries, pay attention to the polarity! Inserting a cell the wrong way in will damage your device.
    • The circuit board indicates the + and - orientation for each cell.
  4. MNT Reform SSD Replacement, Remove SSD Screw: step 4, image 1 of 1
    • Remove the single M2×4 pan head screw securing the SSD to the motherboard.
  5. MNT Reform SSD Replacement, Remove SSD: step 5, image 1 of 3 MNT Reform SSD Replacement, Remove SSD: step 5, image 2 of 3 MNT Reform SSD Replacement, Remove SSD: step 5, image 3 of 3
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its M.2 socket on the motherboard.
    • To avoid damaging its socket on the motherboard, do not excessively lift the free end of the SSD.
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Neelfyn
981 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 619
