MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: step 1, image 1 of 1
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 2, image 1 of 1
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 3, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 3, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 3, image 3 of 3
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 4, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 4, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 4, image 3 of 3
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 5, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 5, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 5, image 3 of 3
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 6, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 6, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 6, image 3 of 3
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 7, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 7, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 7, image 3 of 3
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 8, image 1 of 2 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 8, image 2 of 2
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 9, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 9, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 9, image 3 of 3
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 10, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 10, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 10, image 3 of 3
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 11, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 11, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 11, image 3 of 3
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 12, image 1 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 12, image 2 of 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 12, image 3 of 3
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: step 13, image 1 of 1
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
To remove the replacement faucet, follow steps 1-6.
Manahal Khalil
217 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 870
