MSI GE62 6QF Apache Pro Battery Replacement
  1. MSI GE62 6QF Apache Pro Battery Replacement, Optical Drive: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Battery Replacement: step 2, image 1 of 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Battery Replacement, Bottom Case: step 3, image 1 of 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Battery Replacement: step 4, image 1 of 3 MSI GE62 6QF Apache Pro Battery Replacement: step 4, image 2 of 3 MSI GE62 6QF Apache Pro Battery Replacement: step 4, image 3 of 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Battery Replacement: step 5, image 1 of 2 MSI GE62 6QF Apache Pro Battery Replacement: step 5, image 2 of 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Battery Replacement, Battery: step 6, image 1 of 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: step 6, image 2 of 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: step 6, image 3 of 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
4 other people completed this guide.
Justice Owens
604 Reputation
4 Guides authored
USF Tampa, Team S2-G3, Passmore Fall 2017 Member of USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Members
5 Guides authored
One Comment
Excellent guide! Very straightforward with very clear picture. I was able to replace my laptop battery using your tools and following your instruction! 10/10!
Carl Patterson - Reply
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 67
All Time: 6,787
