Introduction
This guide can be used to help you replace or upgrade the RAM in your MSI GE70 2PE Apache Pro. This is a straight forward repair that requires only a Phillips screwdriver and a plastic opening tool. It should take no longer than 5 minutes to finish replacing or upgrading your RAM.
Remove the six 5.5mm Phillips #1 screws.
Pry the door off using the plastic opening tool.
3 other people completed this guide.
