MSI GE72 6QF Apache Pro Optical Drive Replacement
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: step 1, image 1 of 2 MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: step 2, image 1 of 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: step 3, image 1 of 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: step 4, image 1 of 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: step 4, image 2 of 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: step 5, image 1 of 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: step 5, image 2 of 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: step 6, image 1 of 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: step 6, image 2 of 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: step 7, image 1 of 3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: step 7, image 2 of 3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: step 7, image 3 of 3
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
2 Comments
Why do you have to remove the battery first?
Kevin - Reply
So you don’t have power running through it while working on it.
croberts1290 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,466
