MSI GP60 2PE Leopard RAM Replacement
  1. MSI GP60 2PE Leopard RAM Replacement, Battery: step 1, image 1 of 1
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. MSI GP60 2PE Leopard RAM Replacement: step 2, image 1 of 1
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. MSI GP60 2PE Leopard RAM Replacement: step 3, image 1 of 3 MSI GP60 2PE Leopard RAM Replacement: step 3, image 2 of 3 MSI GP60 2PE Leopard RAM Replacement: step 3, image 3 of 3
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. MSI GP60 2PE Leopard RAM Replacement: step 4, image 1 of 3 MSI GP60 2PE Leopard RAM Replacement: step 4, image 2 of 3 MSI GP60 2PE Leopard RAM Replacement: step 4, image 3 of 3
    • While holding the release tab, remove the battery slowly.
  5. MSI GP60 2PE Leopard RAM Replacement, Back Panel: step 5, image 1 of 1
    • Flip the device over so the back is facing up.
  6. MSI GP60 2PE Leopard RAM Replacement: step 6, image 1 of 2 MSI GP60 2PE Leopard RAM Replacement: step 6, image 2 of 2
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. MSI GP60 2PE Leopard RAM Replacement: step 7, image 1 of 2 MSI GP60 2PE Leopard RAM Replacement: step 7, image 2 of 2
    • Once all four screws are removed, lift the back off.
  8. MSI GP60 2PE Leopard RAM Replacement, RAM: step 8, image 1 of 1
    • Press the tabs on the side of the RAM to remove it.
  9. MSI GP60 2PE Leopard RAM Replacement: step 9, image 1 of 1
    • Slide the RAM out of the slot carefully.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 1,473
