MSI GS70 Battery Replacement
  1. MSI GS70 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: step 2, image 1 of 1
    • Remove all screws using the JIS #1 screwdriver.
  3. MSI GS70 Battery Replacement: step 3, image 1 of 1
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: step 4, image 1 of 1
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: step 5, image 1 of 1
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: step 6, image 1 of 1
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: step 7, image 1 of 1
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: step 8, image 1 of 1
    • Lift the battery and remove.
11 other people completed this guide.
5 Guide Comments
Perfect guide
storolle - Reply
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Reply
Which battery model should I buy?
slackware2007 - Reply
BTY-L76 seems like a good fit
uchadhana (다나) -
I want to replace the battery and lcd cover of the msi gs72 6qe stealth pro. Are the msi gs70 parts compatible with the msi gs72? because I have difficulty finding msi gs72 parts in my country (indonesia)
uchadhana (다나) - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 38
All Time: 9,649
