MSI GT62VR 6RD Dominator Battery Replacement
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: step 1, image 1 of 2 MSI GT62VR 6RD Dominator Battery Replacement, Battery: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: step 2, image 1 of 2 MSI GT62VR 6RD Dominator Battery Replacement: step 2, image 2 of 2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: step 3, image 1 of 3 MSI GT62VR 6RD Dominator Battery Replacement: step 3, image 2 of 3 MSI GT62VR 6RD Dominator Battery Replacement: step 3, image 3 of 3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
Rebekah Johnson
147 Reputation
1 Guide authored
One Comment
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 1,949
