MSI GT62VR 6RD Dominator Cooling Fan Replacement
  1. MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 2 MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 2
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator Cooling Fan Replacement: step 2, image 1 of 3 MSI GT62VR 6RD Dominator Cooling Fan Replacement: step 2, image 2 of 3 MSI GT62VR 6RD Dominator Cooling Fan Replacement: step 2, image 3 of 3
    • Insert the plastic opening tools into the seam on the back plate of the laptop.
    • A popping sound may come from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator Cooling Fan Replacement: step 3, image 1 of 2 MSI GT62VR 6RD Dominator Cooling Fan Replacement: step 3, image 2 of 2
    • Remove the three 2.0mm screws using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator Cooling Fan Replacement: step 4, image 1 of 2 MSI GT62VR 6RD Dominator Cooling Fan Replacement: step 4, image 2 of 2
    • The white plastic clip secures the fan wires to the laptop.
    • Unplug the white clip by grasping it and wiggling it back and forth .
    • Do not pull the clip out by the wires themselves.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,554
