MSI GT62VR 6RD Dominator M.2 SSD Replacement
  1. MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: step 1, image 1 of 2 MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: step 1, image 2 of 2
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator M.2 SSD Replacement: step 2, image 1 of 3 MSI GT62VR 6RD Dominator M.2 SSD Replacement: step 2, image 2 of 3 MSI GT62VR 6RD Dominator M.2 SSD Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the seam on the backplate of the laptop.
    • A popping sound will be produced from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator M.2 SSD Replacement: step 3, image 1 of 2 MSI GT62VR 6RD Dominator M.2 SSD Replacement: step 3, image 2 of 2
    • Remove the single 1.2mm screw securing the SSD to the laptop using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator M.2 SSD Replacement: step 4, image 1 of 2 MSI GT62VR 6RD Dominator M.2 SSD Replacement: step 4, image 2 of 2
    • Remove the old SSD, then insert and screw in the new one.
One Comment
Isn’t that an M.2 Drive not a GPU? the GPU is in the top right. under the heat pipes.
Will Rogers - Reply
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 18
All Time: 1,268
