MSI MS-1782 Back Cover Replacement
  1. MSI MS-1782 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: step 2, image 1 of 3 MSI MS-1782 Back Cover Replacement: step 2, image 2 of 3 MSI MS-1782 Back Cover Replacement: step 2, image 3 of 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 233
