MSI MS-1782 Wi-Fi Card Replacement
  1. MSI MS-1782 Wi-Fi Card Replacement, Back Cover: step 1, image 1 of 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Wi-Fi Card Replacement: step 2, image 1 of 3 MSI MS-1782 Wi-Fi Card Replacement: step 2, image 2 of 3 MSI MS-1782 Wi-Fi Card Replacement: step 2, image 3 of 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 2 of 3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 3 of 3
    • Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
  4. MSI MS-1782 Wi-Fi Card Replacement: step 4, image 1 of 2 MSI MS-1782 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
  5. MSI MS-1782 Wi-Fi Card Replacement: step 5, image 1 of 2 MSI MS-1782 Wi-Fi Card Replacement: step 5, image 2 of 2
    • Remove the Wi-Fi card at its angle.
To reassemble your device, follow these instructions in reverse order and make sure you put the antenna wires back in the correct order.
A'kia
193 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 111
