MSI VR601 WiFi card Replacement
  1. MSI VR601 WiFi card Replacement, Open the back cover: step 1, image 1 of 2 MSI VR601 WiFi card Replacement, Open the back cover: step 1, image 2 of 2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: step 2, image 1 of 2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: step 2, image 2 of 2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: step 3, image 1 of 1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
Geir Ove Andersen
7,752 Reputation
5 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,500 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 212
